Did you find a solution for this problem? My treadmill is now doing the same thing.Did you find a solution for this problem? My treadmill is now doing the same thing.
You can't post conmments that contain an email address.
Hi sir
Hope you are well
This is indicative from EPROM faulty memory.
The firmware is corrupt, you must replace the complete
console control is the computer or CPU or microProcessor.
Call to the company to see if possible to get the version or EPRO only¿
Blessing [email protected]
cell+whatsApp: +50588611441
http://www.manualowl.com/m/Reebok/Competitor-Rt-5.1-Treadmill/Manual/350955 It's look like the engine controller has some fault occurred on it,those board made out of components,as you mentioned motor is spinning but controller not working,so might be liquid damaged through top or faulty circuit refer manual from web ,it's fixable
I will help you inmediately:
Check the circuit breaker to see if it hastripped. If the reset/off circuit breaker has tripped, wait 5 minutes andreset.
If the power cord is properly plugged in, unplugit and wait 5 minutes before plugging it back into the surge protector.
Remove and reinsert the console key.4)Remove the key from the console and UNPLUG THE POWER CORD. 5) Next, remove the screws from the hood and carefully remove the hood. Locate the Reed Switch and the Magnet on the left side of the Pulley .
6)Turn the Pulley until the Magnet is aligned with the Reed Switch. Make sure that the gap between the Magnet and the Reed Switch is about 1/8". If necessary, loosen the indicated Screw , move the Reed Switch slightly, and then retighten the Screw. Re-attach the hood and run the treadmill for a few minutes to check for a correct speed reading.
Thank you in advance,blessing, if you need some additional assistance please reach me. sincerely.
to start off,what type of cable are you using??
since you've already tried using 2diff TVs,basically its with the console
try using a different AV CABLES, if it still doesnt work,try calling xbox support hotline for possible replacement of your cable or for processing a repair for the xbox if necessary..
since you just bought your console,try going back to the store where you bought it and have it replaced, because for the repalcement of the cable if you call xbox support,it will take 8-12business days for toureceive it and 2-3weeks for the turn around time of the repair for the xbox.
you will need to replace the upper lcd screen, when the power light came off it caused the top and bottom shell to shift back and forth causing the lcd ribbon to become damaged, the flash you see is the power from the botton trying to make it's way to the top, send to ebay ed-kar-3 for $38.00 to fix
