Please check and see if the drain filter, pump/valve is clogged or dirty that is not allowing the water to drain off.
If the cycle is not progressing then it is possible that the program controller is not getting the feedback and so inputs the error.
remove and clean the drain sections.
Not knowing what sort of machine you have, one of these should help.
F11 - No hot
fill.The ambient temperature is likely to be below freezing possibly
due to the pipes being frozen. Also check that the taps are on or if
the drain hoses are kinked. F11 - Pump cannot
be activated - Book
a washing machine repair.
F11 - Heater timed
out. The heater has not reached the required level. Book
a dishwasher repair. F11 - No pump
connection - Book
a tumble dryer repair.
