Hi balfbaby,
Instructions including a diagram to insert the battery can be found at:
http://support.sprint.com/global/pdf/user_guides/lg/rumor_touch/rumor_touch_by_lg_ug.pdf
It's located near the beginnging of the document under "Getting Started", then "Setting Up Service".
Hope this helps.
Best regards,
CellPhBuddy.
First of all remove the battery and the memory card from the phone. Use a hair dryer to warm up the battery compartment so as to warm up the set lightly. Now replace only the battery after about 15 minutes back into the phone and switch on. If the phone boots up and comes alive with a touch pad working, then reset phone to factory settings, connect your phone to PC to have a virus scan . Also now have your memory card scanned for virus, remove files and format.
If however the fault stays then you might have to contact LG Service to have the software reinstalled.
