I have a LG washing machine model WD-90150FB. It began to display the error code SE which does not appears on the manual. Could you please tell me what it is?
Tank you very much,
Miguel Lopes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Could be your water pressure too low or tap not letting through properly,take hose off and check
I ALSO HAVE THE SAME MACHINE, I ALSO GET CODES LIKE E1 OR CL. I HAD IT BACK TO THE WAREHOUSE FOR CHECKING AND IT RAN GREAT GET IT HOME AND AGAIN AT TIMES THE WATER ISN'T ENTERING THE MACHINE AND THE CYCLE WILL START BUT IT JUST SIDE TO SIDE. SOME TIMES IT WILL WASH AND OTHER TIMES IT DOESN'T. THE SALES MAN TOLD ME IT NEED TO BE TOTALLY ON A LEVELED FLOOR. IF SO THEN WHY IS IT THAT IT WORKS SOMETIMES. I HAVEN'T CHANGED THE FLOOR OR THE POSITION OF THE MACHINE.
PLS HELP WITH CODE 1E
CDEL VALLE
