SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
SOURCE: water overflow
The water level switch is causing the prob, it could be sticking for one reason or another, for example it could be a partial blockage in the pressure chamber or the hose from the chamber to the switch.,it works on air pressure,so it must be clear of any restriction.
You need to check this before anything else.
Hope this helps solve your prob.
Plz rate my solutiopn.
thanks.
SOURCE: washing machine will not complete the wash cycle
The timer could be sticking OR: Is the machine empty of water when it stops? This information may help solve your problem?
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
SOURCE: My Hoover 500M washing machine overflows and won't
Hi The issue is with the cold water valve that is bad and
should be replaced. Before replacing it you can try to swap the connections
just to make sure if it is the valve. Hope this helps...please post back for
further assistance. Daniel
