There are two reasons that the unit does not respond to the remotes: the antenna is not connected or, the remotes are not programmed to the system. Check to see if the antenna is hooked up. Next, make sure the remotes are programmed to the system. The next time you connect the battery, manually disarm the alarm by turning on the ignition then, press and release the programming button on the antenna.You should here one chirp(disarmed). Try to operate the unit with the remotes after the unit is disarmed.
