This confirms that the wire is open on the inside and so the only job out for you to to have a close SURGERY to be done to rectify .
You must dissect the wire to see the inside layers, now as you tug the free state of the wire will confirm the position of the wire break. Cut and **** the wire sleeve to see the strands where it has come off, use a good soldering iron to solder after cleaning of the wires. Insulate the joints properly with tight taping and bind them together so that the fault will not recur.
