Washing Machines Logo
Posted on Mar 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG Top Load Washing Machine Model: WF-T7517TE , kg TURBO DELUXE. On Pushing START button , MAchine just starts and stops after a second. Message displays "dE". What to do ?
Anonymous
Level 3:
Brigadier General:
  • Master 6,277 Answers
  • Posted on Mar 20, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
6277
Questions
0
Helped
1025555
Points
20216
'de' on LG's stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
I have LG Washing machine ,Model 6.5 KG WF -7517TE Turbo Deluxe Top load .When push start button, Mechine just start and stop after a second, Displays "P E".What to do..????
Hi Santhosh, a PE error code is a water level/pressure switch problem. Could be one of three things. First,a bad wire from the control board to the pressure switch. Second,a clogged pressure tube from to tub to the pressure switch could be clogged. Remove tubing from the pressure switch and blow through it to make sure it's clear. Third is the pressure switch itself is bad and needs to be replaced. Hope that helps.
How to soak somethings overnight in my new LG washer ?
The method we use on our LG WF 8071TTP top-loader:
Load stuff to be soaked.
Add soap.
Set load size and water inlets.
Start wash cycle.
Wait until water is full, and begins washing.
Press Start/Pause button.
Press Auto Stop button to switch machine off.
Next morning:
Press Auto Stop button to switch machine on.
The fuzzy logic (if machine has this) will register that machine is full, and washing will continue.
Lg fuzzy logic 7.kg turbo drum top loader model wf-t7051td does not agitate or spin properly
I would call the washing machine engineer for a quote as there are to many things that can go wrong eric
LG Fuzzy Logic 8.5 kg washing machine WF-T855A Turbo Drum I sensor will not fully spin, stops with 2 minutes to go till end and clothes are in a ball, not spun properly,never had a problem until now??
Unplug the machine over night and then plug it back in the morning. this should reset the internal cycle back to manufacturers specs.
This problem occurs because someone may have opened the door during operations and the onboard computer recognized and remembered this, so it is now part of the standard operating proceedure.
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Problem with my LG washing machine WF-S7012DN model - 7 yrs old. Since yesterday, the wash/m starts to wash takes a turn or two and them stops with alarms on and flashing, (first time problem with my...
there is a magnet controlled switch in the top cover lid and the probable cause the magnet is missing.
The best alternative is just keep a good magnet on the top of lid & slowly move the magnet horizontally.At one point the BEEP stops & machine starts to function.
1helpful
Warning alarm
i am using an LG washing machine model WF-N6861DN.its giving a warning alarm after 3-5 seconds of operation
Lg washing machine wf-t655th won't start
Auto/off is power button--correct?
start/pause button actually starts the unit--correct?
2helpful
3answers
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
