You could try to reset your phone.
Remove your sim card.
Enter *#2767*2878#
That is exactly what free code do. Damage your phone. Your phone is not usable now. You need a cable solution like 'SRS' (unlocksamsungonline.com) to fix this. Otherwise you need to bring it to a shop.
Don't use 'direct unlock' functions but use 'Read codes' function as this will read out 'unfreeze code'. A special code to repair your Samsung.
Best regards,
1. Reboot your Motorola CLIQ with an unaccepted SIM card in.
*If the display reads "Enter Special Code", enter the unlock code and press "OK"
*If the display does not read "Enter Special code":
2. Press and hold the * key until an entry box is displayed.
3. Type *, #, 3, 2, # and press "OK"
4. Enter your Motorola CLIQ's unlock code and press "OK."
5. Your Motorola CLIQ should now display either "Completed" or "Deleted"
Before you can attain your Motorola CLIQ's unlock code you will need the IMEI number on it. You can find the IMEI number by simply typing *#06# and hitting enter. This number is unique to all GSMphone and will help calculate your unlocking code. Once you have your unlock code you are ready to begun the Motorola unlock instructions posted below.
Here are the steps to unlock your phone:
Unlock Motorola CLIQ (SIM Unlock)
Else than services you need to call the service provider for puk code that will refresh all your security passwords and your phone will get unlocked.
samsung c3050 displays phone locked return for service need fix thanks
