How do I access the empty cartridges which need to be replaced?
Hi
1. Make sure the printer is powered on, and not printing.
2. Open the printer cover.
3. Do one of the following:
3a. If the red error light is on (cartridge is empty) press the MAINTENANCE BUTTON.
3b. If the red error light is flashing (cartridge is low) press the MAINTENANCE BUTTON. You will now see the Cartridge Replacement highlighted in Advanced Settings. Select OK.
3c. If the error light is off (outdated cartridge), press the DOWN ARROW MENU button to choose MORE OPTIONS. Press OK, then select INK CARTRIDGE REPLACEMENT.
4. You will now see a message on the display telling you that the ink cartridge replacement will begin. Press OK to continue. The print head will move to the replacement position.
5. Open the cartridge cover. Press in the tab on the back of the cartridge, and lift the cartridge out of the printer. Dispose of it carefully.
6. Unwrap the new ink cartridge. DO NOT touch the green circuit boards, or remove ANY labels.
7. Lower the cartridge into the holder, with the green circuit board facing the front. Gently push the cartridge down until it is firmly seated.
8. If you need to replace another ink cartridge, repeat steps 5-7 above.
9. Close the cartridge cover. Press the front corner of the cartridge cover forward to lock the cover into place.
10. Press OK, and close the printer cover. The printer will begin charging the ink delivery system. Once charging is complete, press OK to finish.
Turn on your printer and lift the access door. The print carriage will move to the center.
