SOURCE: motherboard pin config
All motherboards have a print beside the pins, Speaker= "speak", "pwr s" =powerswitch, "HDDled" red light on front, rst = reset switch [not allways used] "pwr led" Green led, the case wires are usualy marked on the plug ends with the same , "hdd" "reset" and so on. The power switch will work both way's around however the led lights wont. You will not hurt anything if they are the wrong way around, they just wont work so if you dont get lights just reverse the polarity. If by chance the case wires do not have labels the just trace them to the case front panel and plug them into the corresponding board pins. Regards mistyman
SOURCE: CAN'T FIND ETHERNET CONTROLLER DRIVER FOR MY
You can always use a program like driver genius or Boot from a Knoppix cd and run ls pci from the command window. If the card is not integrated in the motherboard pop it out and get the numbers off the card itself.
Worst case scenario is put a 10 dollar pci ethernet card in it :)
SOURCE: need help finding drivers for Systemax Venture
go to this website http://www.systemaxpc.com/support.php
You will find them there. good luck.
SOURCE: I have a very, very
Change your speaker or there may be a chance of problem with your sound card.
