SOURCE: I have a fisher and
Hi there. FC 49 has a few possiblities
1. the wiring connection to the cold water valve has been disconnected
2.the cold valve has failed, compare resistance with hot valve (they should be the same)
3 the motor controller has failed
I hope this helps
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
SOURCE: fisher & paykel fill up with water then
Yep it sounds like another electronics panel has failed.
We never had this much trouble in the old days with the old electric timer machines.
SOURCE: Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Testimonial: "thanks for your help! I will try it out."
SOURCE: my fisher and paykel top loader washing
Disconnect the washer for few minutes (5min) then connect it again and press cancel, before you start any cycle, good luck
