Televison & Video Logo
Posted on Mar 22, 2011
When you turn the power on, the screen will come on for about 4 seconds, then screen will go blank. The screen never loses power.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 31, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
43
Points
Write Westinghouse because too many people have this problem with their Television and they should do a recall or help fix it. After a year and a half of use this is what happens after my warranty. If we all contact them we could get help. make sure they understand we will no longer purchase their product so you will lose stock and go out of business. yes I am pissed. I will tell them I will post this on facebook so the world can see!
1helpful
3answers
Pioneer pro 940hd tv screen goes blank after 3-4
The is due to ether a bad backlight or bad inverter that powers the back light on this TV.
Ether would need repair you can get the parts @ www.partstore.com
Hope this information helps please do click the accept button for my efforts.!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2answers
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
MY PANASONIC MICROWAVE SHUTS OFF AUTOMATICALLY AFTER 3 OR 4 SEC
Sure sounds like it is losing power. First check the fuse and fuse holder. These companies are using really cheap fuse holders and they do not grab the fuse tightly, thye get hot and start to melt the fuse. Remove the fuse and look for signs of heat or flux running from the silver ends of the fuse. if you see signs of it being hot I would replace the fuse and fuse holder. Make sure ALL connections are tight and give it a try. I search long and hard to find fuse holders I like and can trust to do a long term repair. if you cant count on a part, the repair wont hold up and then Its MY reputation that suffers, Damn companies always choosing the cheap way out on making parts. When I started repairing Microwaves, a Home Microwave cost about 800.00 I see them sell at certain stores for 18.88!!!! how can you have good parts in there for 18.88?? Nobody makes things to last anymore. SAD!!! Fill The landfills and buy a new one. except the new one is Cheap Garbage!! Since it goes blank it sound like it is losing power. Always could be outlet you have it plugged into. Try different location first, on different breaker
Picture goes blank after a few seconds of turning on power
check if the back lamps are still on when you lose image, all you have to do is get close to the screen and make is totally black and if is not that means you have a back light working, but if the back light is gone you may have a defective panel.
talked to samsung TA about the same problem I had and the recommend to replace the power supply first to confirm a defective panel because a panel is quite expensive
Phone does not turn on all shown on screen is a still hour
Pull the battery and reinsert, you didn't lose anything. ;)
2answers
Monitor goes blank less than a second after turning on.
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
SMT 5600 does not load OS, screen goes white and then blank.
Screen sound bad, or intermittent connection inside. You can find disassembly instructions on the net. Search with phone model and disassemble. Remove and reattach all cables in case one is lose or contact dirty.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
