Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
Posted on Mar 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a 25.4 cubic Whirlpool side-by-side fridge/freezer stainless steel look. Since the last 2 weeks....the display lights showing temperatures in fridge and freezer the front water/ice dispenser unit on the door has been flickering non-stop and making a clicking noise. It has now become very annoying. I don't think there has been any problems with the actual temperatures in the appliance....just the constant flickering on the front door display is the main problem.
Anonymous
Level 3:
President:
  • Master 2,468 Answers
  • Posted on Mar 23, 2011
Anonymous
Master
Level 3:
President:
Answers
2468
Questions
0
Helped
707040
Points
7484
The clicking is from the lamp relay which makes the lights flicker and its located on the units rear area in the back,without a model number i cant tell what this boards model number is but you need to replace this whole board as they are non repairable(this is usually caused by a power surge or outage,which can destroy these boards,also even if a lamp in the unit burns out this can destroy this board too)
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
2helpful
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Last two weeks refrigerator temp goes anywhere from 30-35 degrees and freezer temp -5 to -1 degrees.several times a day we attempt to set temp to reccommended temp, but no success.we do not have mannual,...
fridge temp should be 30 to 35 degrees/freezer -1 to -5 f or between 2 to 5 C for fridge and -18 to -22 C for freezer several times a day is too often...... try once every 2 days without opening door in between checks....
1helpful
We have Maytag 25 cubic feet stainless steel double door fridge with pull our freezer on the bottom. The fridge as stop being cooled but the freezer works fine?
There is a defrost problem. Ice builds up between the ref and frz sections and wont allow coolo air through. You can also check to see if the damper is stuck closed
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
