Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
Posted on Mar 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jagged horizontal lines from near top of screen to near bottom. Become more prominent as tv heats up
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
709
Points
My akai 42 inch flat screen turns on and gets good visuals but all of a sudden lines of diffrent colors appear across the screen anything i can do to fix it for a cheap price?
Mando Mojica
Level 3:
  • Master 643 Answers
  • Posted on Mar 24, 2011
Mando Mojica
Master
Level 3:
Answers
643
Questions
0
Helped
298884
Points
1928
Sounds like your panel is going bad. usually not economical to repair.
2answers
LG flat-screen TV LED with Horizontal lines on bottom of TV how to repair
The horizontal lines that are showing up on your TV's screen is caused by either a bad cable or a cable that is not correctly fastened to the input and the output ports for the TV and it can cause interference then and the signal and cause horizontal or vertical lines to appear. It could also be the TV"s screen is no longer working and needs to be replaced.
3answers
Two horizontal lines appeared near bottom of screen
You can spend $300 to $500 fixing this or just do the best thing most cost effective thing and replace the TV.
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
2answers
When i turn on my tv it starts with a very distorted picture
got the same TV with the same exact problem....what is it??? if u crack it tell me and i'll do the same...
3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
2helpful
3answers
Horizontal line in My SHARP AQUOS LCD 32'' TV screen
Try to conect with DVD signal in A/V input if good picture, cable line are no good
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Jagged horizontal blue lines everywhere
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
