Question about Cisco Photosmart C4780 Wireless AllInOne Printer With Linksys By Cisco WirelessN Broadband Router
Out of paper - message I receive when I try to print?
    New Friend:
  • 93 Answers
You have some issues with the paper carriage.
You can try unplugging all the cables from the printer and press and hold the power button for 5-10 seconds.
Then plug again the cables and try printing again.
-please vote or thumb-up if you find this helpful. THANKS!!
Posted on Mar 25, 2011
6ya staff
SOURCE:
I receive the following message on the PC display: "Document printing cannot be executed because the paper output tray is closed. Open the paper output tray. Printing will restart". I want to mention
The blinking is just an attention light so there's nothing to worry about that. Try adjusting your paper tray to the paper size you are about to use. Or try checking the duplexer panif its positioned properly. Hope this helps.
Dec 20, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
Message shows out of paper during copy or receiveing a fax
Take it back. It is broken. If It was older I would suggest some things, but it would probably invalidate your warentee
May 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
When printing paper continues to jam.
  1. Take out paper tray 1.
  2. Remove any jammed sheets of paper you find there.
  3. Once you have done this, reinstall the paper tray and try printing again.
    Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
  4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
Dec 16, 2008 | Office Equipment & Supplies
"DARK PAPER USED" Message
I found a copy of the manual, and on page 202 the "Dark Paper Used" message can be caused by three things:
1. Paper used is colored or stained -- replace with clean white paper.
2. Paper was pulled from machine before the fax was ejected completely.
3. The received document support is not installed correctly. Page 3 in the manual shows this support as the rear-most, and it looks like it should be installed with the upright portion angling toward the rear at about a 30 degree angle.
Sep 02, 2008 | Canon FAX-B160 Plain Paper Bubblejet
Error message says "memorry full" will not let us fax or scan for Konica Minolta 290MF
The FAX machine received some FAXes while it was without paper. Make sure the FAX has paper and try printing the stored faxes or check in the fax menu if they can be cleared without printing.
Another problem may be that the FAX received not faxes but voice messages, retrieve and delete the messages and the error should be gone.
May 05, 2008 | Office Equipment & Supplies
Printing problem
Haven't fixed the problem and was trying your site out to see if it delivered gratis.
Mar 29, 2008 | Office Equipment & Supplies
PAPER JAM MESSAGE, BUT CAN'T FIND ANY JAMMED PAPER
look at the paper tray,some of your sensor are jammed,try tyo find out where is the sensor on paper try
Feb 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
I860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Nov 06, 2007 | Canon i860 InkJet Photo Printer
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Received fax's are not printing. Unit prints confermations and is working as a printer but recieved fax's just park in memory and will not print.
TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING. IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING, IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY. HAPPY FAXING OMNIPRESENT
Jul 28, 2006 | Samsung SF-560 Plain Paper Laser Fax
Cisco Photosmart C4780 Wireless AllInOne Printer With Linksys By Cisco WirelessN Broadband Router Logo
159 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
