If it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Can I adjust the front drive belt on an A2550 treadmill?
I'm having this problem. Do you know how to fix the motor/drive belt? The motor runs, but the belt just stops. It looks like the pulleys are out of alignment. We put the belt back on once, but it came off again while I was running, and the belt stopped. Thanks!
Check page 27 in the owner's manual:
"If the walking belt slips when walked on, first remove
the key and UNPLUG THE POWER CORD. Using
the allen wrench, turn both rear roller bolts clockwise,
1/4 of a turn. When the walking belt is correctly tightened,
you should be able to lift each side of the walking
belt 3 to 4 inches off the walking platform. Be
careful to keep the walking belt centered. Plug in the
power cord, insert the key, and carefully walk on the
treadmill for a few minutes. Repeat until the walking
belt is properly tightened."
