Sony KDS-60A2000 60" HDTV Logo
Posted on Mar 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I replaced the bulb on the kds-60A2000. Now the red LED power light is blinking 3 times. I know that indicates the lamp door may not be securely attached. I have replaced the bulb before and had no problem. I am sure the lamp door is on correctly. I am not sure how the TV knows the door is not secured. Is there a sensor or a switch I would be able to see? Thanks for your help
Mando Mojica
Level 3:
  • Master 643 Answers
  • Posted on Mar 26, 2011
Mando Mojica
Master
Level 3:
Answers
643
Questions
0
Helped
298929
Points
1928
The tv know the door isnt on because of an internal switch. Make sure all doors are on usually three blinks indicates door isnt on. If the tv still doesnt power on your balast might be out.
How to get a picture on sony FULL HD 1080
Hi. Not shore of this model but could be a bulb replacement is needed, Or one of the filter covers may not be making contact.
The red light is indicative of error rather than working ( green ) or standby ( orange ).
I hope you get it sorted.
1helpful
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
3helpful
2answers
I HAVE A SONY KDS-60A2000 WONT TURN ON. RED LIGHT BLINKS THREE TIMES. TRIED NEW BULB. NO DIFFERENCE
3 times red light blinking indicates that Lamp Cover has not been fixed in its location properly after lamp replacement.
Please make sure lamp cover (its first thing that was removed to replace lamp) is installed securely.
Thanks.
2helpful
My power light is flashing red three times on and off. sony kds-60a2000 is the model, what do i need to do?
The 3 blink code indicates that the lamp door is not secure. If you havent removed the door then its probably the switch for lamp door sensor.
I would remove the lamp door and then reinstall it. Do this with the set unplugged then plug it back in and check operation.. Basically sometimes the lamp door switches become dirty and by removing and reinstalling the door it usually corrects the problem..
If this doesnt work then you will need to either have the set checked out by a tv technician or you can try replacing the switch yourself. But as I said normally just removing and reinstalling corrects the problem.. Good Luck!
1helpful
Sony KDS60A2000. I replaced the lamp but the message came up and said I did not. I did not know about the reset timer in the set up. Now the tv will not turn on.....just 3 red blinking lights where it says...
According to the manual (pg 53) : "If the lamp is not securely reattached, the self-diagnostic function may be triggered and the POWER LED blinks three times."
3helpful
Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
1helpful
2answers
My tv sony kds-50a2000 dont tur ON
I have a Sony KDS-50A2000 50 in. HDTV Television. I just replace the lamp because I got the message that appeared on the TV. Lamp needs to be repaced. I replace with a Sony lamp and now TV cut off after 2 to 3 hours off watching the TV. Any Idea what is going on with this TV
1helpful
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
