Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
There's no guarantee that you would be able to 100% unlock your DVD player. But you can try creating a region free copy of your DVD collection to play on your DVD player so that the region code on your DVD player won't be an issue. Check out Leawo Blu-ray Copy, it can create region free copies of your Blu-ray/DVD discs. Check out how the program works in this post: How to Make 1 1 Disc to Disc Blu ray Backup with 1 Click Blu ray Copy...
