SOURCE: Samsung i85 camera. Tried
i had the same problem it was stressing me out... 1st you must go into "my computer", click on "removable disk", there should be a file named "DCIM" (yours might be different), where you see this file create a NEW file on that same pg named "MP3". now when you go to download songs just download them straight to that file. hope that helps
SOURCE: Samsung s830 SDHC Problem?? Camera Dies!!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
SOURCE: Card Locked Samsung SL 102 Camera
there is a lock button on the memory card check it if it is SD card or camera might not support the card try 1gb card
SOURCE: Recover pictures from iinternal memory
You may need to try some photo recovery software to rescue the pictures, here are some for your option.
Photo Recovery (for Windows)
Photo Recovery for Mac
Note: Before your files are recovered, do not attempt to save more files to the camera.
SOURCE: My Samsung Digimax A7 camera
The Digimax A7 may not be compatible with "High Capacity" SD Cards (SDHC). If this is the case you will need to locate an SD card that is 2GB or less in size as anything larger than this is a high capacity card.
SD card wikipedia page
