I just bought a 40" Westinghouse at BestBuy and had the same problem. My TWC remote still had the code from my old analog Samsung. Fortunately I kept the code sheet from Time Warner and using the 3 digit method reprogrammed it. Westinghouse uses 4 dif codes on their LED-LCDs. Here are the 3 digit code nos. 076 276 435 001. I ran thru the first 3 and mine was 001. Whoever your provider is use their remote to do this and not the one that came with your set. I used that remote to make all the adjustments on my set to fine tune it, color, sound, etc.following the menu. Hope this helps.
By "sound but the screen on my westinghouse 32 inch flat screen is solid lime green" Do you mean that you have sound but the screen is green? If yes it means that an analog signal is being fed to a digital input. Did you recently change the input cables at the back from one port to another? If not then please describe what are colors of the cabels you are using(Yellow, Red, White or Red Blue Gren etc.,) and what port they are connected to so that I can tell you whether its a problem with the connections or the tv itself.
Usually a color missing is a bent pin if you are using it as a PC monitor. Definately check your cables and see if the problems follows the input selections. If it does it most likely is a electronic component failure. Of course this assumes the settings aren't randomly messed up. You might be wanting to invite that guy that always has things taken apart when you visit...or start watching online sales...head's up on repair bills...a similar product costs $400 new, 300 refurbished.
its ok, pause the screen and get a wax crayon the colour that you want the peoples faces to be and colour over them on the screen. when you have fully enjoyed that frame scrub it off and pause the video 1 second later. eventually you will make the whole movie like this the exact colour you want it.................
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
