Reinstall Windows from a Disk 1 Turn on your Toshiba . Insert your recovery disk or the original
Windows operating system DVD into the 's CD/DVD drive. Turn off the computer. 2 Turn on the Toshiba . In the first few seconds while it is
starting up, press and hold the F12 key on your keyboard to access the Boot
Menu. (Note: Some Toshiba models may tell you to press "C" to boot from the CD-ROM). The screen will display boot for this boot up
session only. 3 Use the arrow keys to navigate. Select the CD-ROM/DVD drive to
highlight it. Press "Enter." Be aware that this setting is for this
session only; it is not a permanent change. 4 Allow the computer to start up. Follow the onscreen instructions
for reinstalling the operating system from the disk. Reinstall from a Recovery Partition 1 Boot up the Toshiba . In the first few seconds while it is
starting up, press and hold the F8 key. This will begin the "Advanced Boot
Options" menu. 2 Use the arrow keys on your keyboard to navigate the menu. Move
the keys to select "Repair Your Computer." Press "Enter." 3 Select your language and keyboard; click "Next." 4 Select your Windows user name from the drop-down menu. Enter
your password if required. Click "OK." This will begin the
"System Recovery Options" menu. 5 Select the Toshiba Recovery Wizard and follow the onscreen
instructions. The Toshiba Recovery Wizard will delete all existing data on the
hard drive and reinstall Windows. Hope this helps!
