might need to format the flash drive to the phillips dvd player. make sure you back up whats on the flash drive first. plug into dvd and format it. the player should ask you if you want to format flash drive. because when you format the flash drive it will erase all data on it. then reload the data back on the flash drive. try again
hi, to make ur player region free for dvd u should have a Oneforall universal remote wich acept 4 digit code Firs of all u have to program the remote for the purpose. procedure is as follows
Full procedure for a oneforall remote is as follows:
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079 28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDP-S360 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light)
3. Put the player back into standby with the Sony remote.
4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely.
5. Next time you turn on the player it will be region free for DVD playback.
ok
Sony BDP S350 bluray - unlocking to region free
Yes, it is possible, but you'll need a programmable remote - most use the "one for 3/4/6/all". You can hack it by using the same code as for the bdp-s350. Follow the instructions exactly and it should work - mine does.
Programming the 7040 OneforAll remote to enable region free playback of DVD's on the Sony BDP-S350Quote:1. Press DVD
3. Press 0533
4. Hold the magic button until the DVD button flashes twice.
5. Press 994
7. Press 1891 (this sets key 1 - the DVD button flashes twice)
8. Hold the magic button until the DVD button flashes twice.
9. Press 994
10. Press Magic Key (don't hold)
11. Press 2552 (this sets key 2 - the DVD button flashes twice)
12. Hold the magic button until the DVD button flashes twice.
13. Press 994
14. Press Magic Key (don't hold)
15. Press 0953 (this sets key 3 - the DVD button flashes twice)
16. Hold the magic button until the DVD button flashes twice.
17. Press 994
18. Press Magic Key (don't hold)
19. Press 2214 (this sets key 4 - the DVD button flashes twice)
20. Hold the magic button until the DVD button flashes twice. .
21. Press 994
22. Press Magic Key (don't hold)
23. Press 0795 (this sets key 5 - the DVD button flashes twice)
Done - the remote is now programmed and ready to use
Quote:
1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed
2. Make sure there isn't a disc in the machine.
3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing)
4. Put the player back into standby with the Sony remote
5. That's it, the next time you turn on the player it will be region free for DVD playback
If the blue 24p light doesn't flash then it hasn't worked, try a new set of batteries and start a fresh
Good luck
one for all rc 7652 works for this as do many others. 1. Press DVD
3. Press 000533
5. Press 994
7. Press 001891 (this sets key 1 – the DVD button flashes twice)
9. Press 994
11. Press 002552 (this sets key 2 – the DVD button flashes twice)
13. Press 994
15. Press 000953 (this sets key 3 – the DVD button flashes twice)
17. Press 994
19. Press 002214 (this sets key 4 – the DVD button flashes twice)
21. Press 994
23. Press 000795 (this sets key 5 – the DVD button flashes twice) Done - the remote is now programmed and ready to use
Quote: 1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed
5. That’s it, the next time you turn on the player it will be region free for DVD playback
I personally dropped the 00 that are marked red and it worked for me but it depends on model of one for all remote.
Yes there is a hack to make the DVD region free, as far as I know there is not one for the Blu-Ray as yet.
You will need your original remote and a 7040 OneforAll remote to enable region free playback of DVD’s on the Sony BDP-S350.
Programming the 7040 OneforAll remote.
1. Press DVD
3. Press 0533
5. Press 994
7. Press 1891 (this sets key 1 – the DVD button flashes twice)
9. Press 994
11. Press 2552 (this sets key 2 – the DVD button flashes twice)
13. Press 994
15. Press 0953 (this sets key 3 – the DVD button flashes twice)
17. Press 994
19. Press 2214 (this sets key 4 – the DVD button flashes twice)
21. Press 994
23. Press 0795 (this sets key 5 – the DVD button flashes twice)
5. That’s it, the next time you turn on the player it will be region free for DVD playback If the blue 24p light doesn’t flash then it hasn’t worked, try a new set of batteries and start a fresh
You will have to reset the DVD player in order to undo the progressive scan option. Since you cannot see a menu to do so...
1. Unplug the dvd player from the outlet 2. Press and hold down the STANDBY-ON m button on the front of the Recorder while reconnecting to the power outlet. 3.Release STANDBY-ON m when ' ' appears in the display. All the information stored in the memory (programs, time, TIMER) will be reset (cleared).
Hope this helps with your problem, thank you for stopping by Fixya! Please leave a positive rating if this solution works for you.
I had the same problem and searched FIX and found a solution for a Phillips DVD player that worked on my Sony DAV-FC7 dvd player. Someone posted that they called their Phillips Tech Service and was told to (a) unplug the dvd unit from the wall and wait 20 seconds,then (b) press the standby+plug the unit back into the wall at the same time and hold for 10 seconds. I did this for my Sony DAV-FC7 which would not power on nor eject (just red light on). IT WORKED!! after doing these steps, my SONY powered on and the rented DVD ejected. The dvd palyer works again. Thanks fellow FIXYA "posters".
THe standby light is flashing and it is not responding to any buttons.
Same here. Blech.
absolutely the same problem
