I have canon power shot sd1000 camera. Every thing is o.k. except that recently the screen stays dark in picture mode and when on for taking pictures. pl let me know.
To autofocus the sensor needs a fair amount of contrast (light and dark eges) to operate. If you're trying to take a photo in a dim room of a dark colored subject for instance the focus won't lock and the camera won't take the picture. Try switching your lens to manual focus and shoot that way.
CCD imager chip is defective in your Sony DSC-T1 camera that is why you see no image in lcd screen. Replace ccd imager chip to fix the camera problem. Local camera repair shop will help you to replace bad part if you have no experience of electronics stuff repair.
If your device gets covered in water, act fast and rationally, and you may be able to save your device. 1. DO NOT TRY TO TURN IT ON 2. Pull out the battery. 3. Please your device and battery into a bowl of uncooked rice to absorb any moisture. 4. Please it in a warm, dry place where it can receive direct sunlight. 5. Be patient. It is recommended that you leave it in there for at least 48 hours. 6. After 48 hours, put the battery back in and power on.
I have a sony cybershot DSC-S650, the LCD was very dark and could not
see anything except if I pointed it at a bright object, everything else
worked ok. I could take pictures but could barely see them in playback
as well.
I took it to Sony authorised repair outlet and was told
the CCD was damaged, they charged me USD $55 to repair it (in Quito,
Ecuador)
as well.
Ecuador)
some cameras have a choice in menu as to monitor or continous autofocus-monitor or continous means camera always seeks a focus which hurts bat life but makes focus quicker-single means camera won't focus untill button pressed halfway-make sure you are not in macro mode-flower icon on screen-this will screw up focus except for close up work-good luck-check menu settings for your type of focus
That would explain the darkness if the lens is stopped down. It would seem the aperture control is faulty on the camera body. Normally, the aperture remains open until you take the picture. It is only closed down while the shutter is open.
hi melissa,
your problem is the focusing areas, im sorry that I do not know how to turn it off, the rectangle you see is the area is focusing on, and the darkness is what the camera doesnt focus on, try reading the manual, or turning it off yourself.
This is weird, usually shutter delays are caused because camera is trying to focus first, it really shouldn't happen after pre-focus. do you have a manual focus mode? if you do, try it and see if it works. if you dont, I would still suspect it some kind of focusing problem, but unfortunalty i have no idea how you can fix it yourself.
