You can try code 0463, although its a long shot.
Alternativley....this may work (a manual code search):
Turn on the device that you want to control. (TV)
Then press that device key on your remote once and release (the TV key as an example).
Press device key a second time and hold for at least 3 seconds, and release.
Hopefully,
the device key is now flashing. Next, start pressing channel up
repeatedly until the device you are trying to control turns off. When
this happens, press the device key, this will lock in the code.
Note:
When the device shuts off, you may have hit channel up before your
brain realizes what happened (i.e. you will be one code off...so hit
channel down and then the device key if you think you went to far)
Hope this helps!
