Question about Whirlpool Duet GHW9150P Front Load Washer
I get the DL on my washer - Whirlpool Duet GHW9150P Front Load Washer
  • 403 Answers
Door Lock Error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
•Door Lock Mechanism broken or removed from the Door
•Check Door Lock/Switch Assembly
•Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
•Door Lock/Switch Assembly Failure
Posted on Mar 28, 2011
6ya staff
SOURCE:
What wrong with my washer when it says DL
your washer has problem with door switch replace it.it will work fine.
Feb 15, 2013 | LG WT5001CW Washer
F dl I get the clicking and F with dl. The washer does not come on.
Hi
Error F dl indicates door latch failure and to resolve this issue you'll have to replace the door latch assembly. Also before doing this you can leave the washer unplugged for 30 minutes and then check the door latch assembly, if bad replace it. Please post a comment if need more help.
Thanks
Rylee
Oct 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Washer reads dL f and door stays locked even
try to start another cycle then hit cancel and cancel again and it usually unlocks the washer
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite HE4 has fault code of dl and F?
F-DL code is for your washer and if the main control has not been replaced then that is what I would replace most of the time F-DL is also seen with a F-11 code later in the cycle, i am sure you hear the washer try to lock the door a few times and pop up F-DL. the main control part # is based off of the model#
Sep 25, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer flashing dl on the screen
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
205 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
