How do i change the backlight settings?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
5E 0NC02 001 4H 0NC02 A01 ASUS 5E 0NC02 001 Power Supply Backlight...
SOURCE: screen comes on but goes dim within seconds
The inverter in the monitor is probably going bad. It can be replaced, depending on the size/age of the monitor. Many times it is cheaper to buy a new one than to have it fixed.
If you are a little handy, and can get the monitor open, you can find the inverter and replace it. The monitors have a high voltage area you have to be very careful around.
New inverters range from $30-75. They are very specific to the model of monitor. The best way to find one is to get to the inverter and search for the numbers printed on it.
A repair might cost you $100+
SOURCE: input select button to switch between hdmi/dvi/vga
Unless there is simply some dirt or dust caught in it, I would imagine that the button has lost its 'spring' or bounce-back ability which means that either you can take the big risk of attempting to fix it or come up with some other clever way to give it bounce.
SOURCE: HANNSpree monitor screen going blank
Sounds like either the inverter board is failing - or it may be the power to the inverter board. Look up your model# on eBay and you may get some insight as well as a source of parts.
