SOURCE: geneve gold wrist watch
if no possible joints can be seen at back it can be open through glass.find an expert on watches.
SOURCE: Hello, I hope you can
We need to know movement number to find out exact battery for your watch. Number is pressed on movement plate.
SOURCE: Question:how to set the weekday on a Fossil watch model BQ-9165.
You have to pull out the stem all the way and turn clockwise until you get to the correct day. Hopefully you won't have to wind thru the whole week.
SOURCE: WHAT TOOL DO I NEED TO REMOVE THE BACK OF FOSSIL
Most watch backs either screw off with a special case opener that every wachmaker uses or pried off with a knife like case opener or sometimes a knife. Take this to your local watchmaker for battery replacement. Batteries are readily available but are a bit tricky to install properly and are best installed by a qualified watchmaker.
