Washing Machines Logo
Posted on Mar 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a F&P Smart drive 051 Model LW015-F Product 91918 Washing Machine. Pump won't run in machine. Have removed and tested pump ok. Can't see any blockage in hose or manifold where pump connects. Have read advice about socks getting stuck; Do you need to access this area from inside the tub? If so, after removing the central agitator piece, do i need to unscrew the exposed screws?
keith jones
Level 3:
Master:
  • Fisher and P... Master 747 Answers
  • Posted on Apr 21, 2018
keith jones
Level 3:
Master:
Answers
747
Questions
Helped
314682
Points
1478
If you didnt run the pump on the bench dont be fooled by any readings it canstill be stuffed
4 Related Answers
Anonymous
  • 159 Answers
  • Posted on Jul 12, 2007
SOURCE: Washing machine will not drain
The ball is part of the system. They float up when there is water in the washer and as it drains if go's down. It sounds to me you must have a blockage somewhere, if you know the pump is operating in the drain cycle. If your sure there is no blockage and the ump is working I would replace the pump. On electric pumps they may work but if the impeller is worn from something that got into the pump it will spin but not pump the water out. Hope this helps you.
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on Jun 08, 2008
SOURCE: Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Anonymous
  • 686 Answers
  • Posted on Apr 06, 2009
SOURCE: missing sock in Maytag Atlantis
it's a possibility that the socks have gone under the agitator but unlikely that they have disappeared alltogether. You can remove the agitator to see if they are there. Tha'ts the best I can tell ya Good Luck
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jun 08, 2009
SOURCE: TOP LOADING WASHING MACHINE HAS A SOCK STUCK IN
flip up the control panel and pop the cabinet clips. Remove the cabinet and the pump is right in front. All you need is pliers and a screwdriver.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
I have a Fisher & Paykel Smart Drive 051 which is old
If your Fisher & Paykel washing machine is making a clunking noise and seems to be washing in the same direction, it may be due to the drive belt. The drive belt helps to rotate the drum of the washing machine and over time, it can become stretched or damaged. To fix this problem, you will need to replace the drive belt.
1helpful
2answers
Fisher and Paykel Smart Drive Pride 5.5 washing machine will not pump water out...makes a beeping noise when trying to pump water out.
I own and have repaired my smart drive washer. The water pump is very simple to remove on these machines. Unplug the machine and drain as much water from it as possible. There's a small plastic locking tab on one side of the pump. Gently pry it away from the body of the pump and twist the housing until it comes free from the metal pump housing anchor plate. Unplug the pump from it's connection and remove it. Found a guide that should help you -
How to Drain Washing Machine That Won Empty Cares Appliances
Washer won't drain, rinse or spin
Water will not drain from machine
1.kinked or clogged hose----clean drain hose
2.pump does not run----readjust & tighten pump-drive mechanism
3.suds lock----remove suds,, add cold water
4.faulty transfer valve---replace
5.defective timer----replace
6.loose belt---adjust belt
I have an toploader smart drive (about 12 years old now). I added some clothes to the machine last minute throught the cycle and now its just stopped. Dashboard lights come on but it wont drain or...
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
My smart drive model LW015-K top load washer won't drain the water, I think the draining mechanism is blocked but Im not sure. I forwarded to spin cycle to force drain but it just makes a buzzing sound...
sounds like blocked or the pump is shorting out, do not keep using it otherwise the pump can short your board out, get a repairman unless your a handyman
its easy if you know how hahahah the pump either has something jammed in it or its faulty
It does not spin anymore. Something blocking the pump? It wants to spin but doesnt seem to be pumping the water out.
Was there an eror code 37 or did it beep continously during this part of the cycle? - then yes its likely a replacement pump is necessary.
Anyway you seem to have kinda figured nout what is wrong with the machine - the problem is there are 2 types of pumps
Early models with the traditional agitator - pull away from wall & tilt backwards so its on about a 70-80 deg against wall - you will see the pump if an older model located on right side - a twist & locking mech to remove with a clip on and a earth wire to a push on terminal to pump frame.
The later model is a smart pump - a bit differrent but i think the above applies to your machine - if I knew the product code I can guide you the the correct procedure.
8helpful
How to I get to the pump on my Fisher & Paykel Smart Drive 9 Pride 5.5?
If machine has water in it, bucket out as much as you can.
To access pump:
-Pull machine forward and lean it backwards so you can access under machine.
-On the front right hand side, you will see a fan blade- this is the drain pump. This fan blade should spin freely if you turn it by hand.
-To remove pump: remove plug connection that has 2 wires. Remove other plug connection that has 1 wire. On the top of the pump assembly, you will see a white plastic tag, about a 40mm long horizontally across the pump- gently pull tag towards you, and turn complete pump unit anti clockwise- whole pump will drop out (don't force it, it should come out easily) *Note* if there is water in machine still, it will come out when you remove pump assembly- be ready with some towels!!
-Check pump impellor(blade on other end of pump) is free from obstruction, and turns easily. Check with your finger to see if there is any obstruction in the hole where the pump has come out of (inside bowl).
-You can test pump with an ohm meter (should be approx 37ohms from memory)
Reassemble and test for leaks etc
Fisher&Paykel Smart Drive 051 keeps beeping/not draining
Hi, I have the same problem and for my wahsing machine it is block pump, so I turn the machine on and advance it to spin and turn the pump fan to help clear the block, the pump locate at the buttom of the basket of the machine...
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
