You need to do some setups for the internet.
For AT&T
Watch the YouTube video on internet setup for AT&T
WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to
[email protected] (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to
[email protected]
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port
is 8080
Edit the Username to
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Email will not work with any server that requires smtp authentication (which
is pretty much all of them here)
There is no java in the browser. Forget it. There is also no java loader so
there is no downloading java games. Copying them to the SD card won't work
either. No java loader so the file will be unrecognized.
Wap services like gmail, yahoo email and wap based instant messagers work
fine. Make sure you have a good unlimited feature so you do not incur overages
from over using your new toy.
For T-mobile:
This is the one that worked for me - I have the $5.99 TMobile Web plan:
Create Data Account
1. Select Menu
2. Select Entertainment
3. Select Services
4. Select Data Account
5. Select GPRS
6. Choose an empty profile
7. Account Name enter T-Mobile WAP
8. Press Options
9. Press Done
10. APN enter wap.voicestream.com
11. Press Options
12. Press Done
13. User Name >Leave Blank<
14. Password >Leave Blank<
15. Auth. Type choose Normal
16. Press Done
17. Press Save
Create Profile
1. Select Menu
3. Select Services
4. Select WAP
5. Select Setting
6. Select Edit Profile
7. Select a profile
8. Choose Edit Profile
9. Rename Profile enter T-Mobile WAP
10. Homepage enter wap.myvoicestream.com
11. Data Account select GPRS
12. Select T-Mobile WAP
13. Connection Type select HTTP
14. Proxy Address enter 216.155.165.050
15. Port enter 8080
16. User Name >Leave Blank<
17. Password >Leave Blank<
18. Press Done
19. When prompted to SAVE please select Yes
20. Select Activate Profile
21. When prompted to Activate Profile please choose Yes
22. Press Done
If you have the $19.99 or higher plan replace the following:
Step 7 under Create Data Account:
Optional - change name from TMobile WAP to TMobile "whatever"
Step 10 under Create Data Account:
use wap.voicestream.com or internet2.voicestream.com or
internet3.voicestream.com instead
and
Step 9 under Create Profile:
Step 10 under Create Profile:
change to www.tmobile.com - may not work so try google.com also
SMS, MMS AND VOICEMAIL
1- Click on thee envelope icon it will take you to Messages
CLICK ON SMS
1- Message settings--> click in Profile Setting
2- Click edit on any profile name it T-mobile that will be line No. 1 in No.2
type +12063130004
MMS
1-Message Settings-->click Server Profile
2-Click on any 1--> click on Edit Profile
1- Rename profile
T-mobile MMS
2- Homepage
http://216.155.174.84/servlets/mms
3-Data Account
click on GPRS--> choose Tmobile--> press OK
4- Connection Type
HTTP
5- Username
leave it blank
6 Password
leave it blank
CLICK ON DONE --> SAVE-->ACTIVATE PROFILE
VOICEMAIL:-
Edit it--> name No.1 Viocemail
No.2 +18056377243
NOTE:
Whenever the phone will ask you for a proxy address and port number.
You need that info to be able to get your sevice to work
Here is that info ...
Proxy: 216.155.165.050
port: 8080
