Nokia N95 Cellular Phone Logo
Posted on Aug 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No screen and button or key pad light sometimes
The problem was the screen and button or key pad has no backup light but the phone its working alright.Sometimes all light is working and no problem at all.If you think i have to replace parts please let me know.
Anonymous
Level 3:
President:
  • Master 1,952 Answers
  • Posted on Aug 05, 2008
Anonymous
Master
Level 3:
President:
Answers
1952
Questions
0
Helped
698047
Points
5792
It may be a loos connection...no need to change any parts..better u give to service
KEY PAD NOT LIGHTED
On candybar style push-button phone units, this indicates non-working or failed LED backlights.
Some phone models will have an option to turn off the backlight for both screen and keypad. This will normally be in the Settings Menu of your unit, and sometimes found in the user manual.
Hope this helps.
Nov 05, 2013 • Cell Phones
1helpful
I have a samsung g600 but the top part of the buttons wont work what can i do?
Hello !
Your phone innner key pad is damaged thats why is not working the best solution ( test) I suggets a technician to swap the innner key pad to see if okey .
Beacuse sometimes stuff like steam ,juice ,water form a coating ( rust ) that affect the pad plates and brings poor contact , Also the mother board key pad contacts should be cleaned .
Good luck
1helpful
1helpful
Moto Q Sprint Phone wont turn on
3 ways to solve it:
1.) Take out and put battery back in.
2.) Plug into a wall or car charger but not a PC USB charger. This does not work with PC USB connection for some reason.
3.) Hold red on/off button to force a reset.
4.) The big battery icon should appear on screen.
5.) Let charge until mostly or fully charged.
7.) Turn on phone. It should boot.
2 - Hard Reset
To perform the hard reset, hold down the center select button in the middle of the D-pad/joypad (the raised silver one.) Then, continuing to hold it for at least five seconds, press the power button to allow the device to power up. Continue to hold the select button until you get a screen which asks if you want to perform the master reset. Let go of the select button, and press the appropriate soft action key to respond yes.
REMEMBER! A hard reset erases ALL of your data!!! This is why the Backup is so important.
You could get Sprite Backup. In addition, install it to your Storage Card and save your backups there as well. That way you can restore on the road without a PC.
3 - Update your phone's firmware
5helpful
2answers
U700 touch keys
The FLEX (white film strip inside your sliding phone) is already worn out. if your phone is still covered by warranty, it will be replaced for free by any samsung mobile service center, but if not, you have to pay for its replacement..
Motokrzr k1 problem
my phone turns on but the key pads not working do you no how to take the key lock of
Back light
Its a screen problem...
2answers
Samsung- SGH-D820 key problem
Contact problem more common with any phone. Simply problem, somtimes you have to take a part the phone clean it, dry it to fix that.
You can buy a special cleanig solution for wather dammage from ebay if you realy want to fix this alone.
But if you hawe waranty, use ti!!!
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
