please sir, mine too displays the same thing yet there is no single peace of paper in, i have opened to check several times.please sir, mine too displays the same thing yet there is no single peace of paper in, i have opened to check several times.
You can't post conmments that contain an email address.
ok mate. when you open the right cover, there is a registration roller on the side. the registration roller is black one. it is visible from the side. rotate that roller and the paper should come up. rotate that roller with hand.there is a small piece of paper stuck below that registration roller which is not visible.
ther is a paper jam in the machine, open the side cover and remove the paper jam, if the paper is not visible then there is a small piece stuck somewhere.
To replace the ETB Belt.. follow this step..but it would be easier if I can show u the diagram.. I will figure a way to upload. but let see if u understand here... ETB removal and replacement Use the following procedure to remove the ETB (RM1–1881–000CN). 1. Remove or slightly pull out Tray 2 (RM1–1916–000CN). 2. Remove three (3) screws, two (2) from the right cover assembly and one (1) from the left cover assembly. 3. Open the front door. 4. Remove the right cover (RM1–1858–000CN), carefully twisting the front edges of the side covers outward to remove. NOTE : To make the removal of the right cover assembly easier, release the tab on the inside of the cover. 5. Remove the left cover. 6. Squeeze the white link lever on the left side. 7. Remove the screw on the right white plastic catch, and then remove the plastic catch. 8. Close the ETB. 9. Remove the small black cable cover (RC1–5147–000CN) on the left side of the printer by carefully snapping it out of place. 10. Remove one (1) grounding screw from the ETB harness. 11. Pull out the white wire holder by pushing it up. 12. Pull out the ETB connector. 13. Remove one (1) screw from each hinge cam on both sides. 14. Using needle-nose pliers, remove the hinge left cam (RC1–4249–000CN) and the right hinge cam (RC1–5311–000CN). 15. Remove the ETB.
Use the following procedure to replace the ETB. 1. Align each foot of the ETB with the respective holes, securing the right side first, and then the left side. 2. Complete replacement by following steps 1 through 14 above in reverse order. NOTE : When replacing the right cover, align the tabs on the upper edge of the right cover and lower edge of the face-down cover with their respective slots.
1 Unplug the power cable.
2 Remove the paper delivery tray assembly
3 Remove two (2) screws from the right cover assembly
4 Remove the right cover assembly, carefully disengaging the catches
5 Unplug the control panel cable.
6 Insert a screwdriver to loosen the release tab on each side of the upper face cover
7 Remove the upper face cover
8 Remove four (4) screws from the upper cover
9 Lift up and remove the face-down cover
10 Remove the output tray by releasing the tabs.
11 Unplug the harness from the fuser motor
12 Open two (2) clips and remove one (1) clip to remove the fuser connector.
13 Unplug two (2) 3-pin optical encoder wires
14 Unplug the red high-voltage bias wire.
15 Remove the thermistor wire.
16 Remove the cables from the wiring harness.
17 Remove three (3) screws from the fuser chassis.
18 Gently rocking if necessary, roll the fuser forward to remove.
Use the following procedure to replace the fuser.
1 Align the fuser tabs with their respective holes.
2 Complete replacement by following steps 1 through 18 above in reverse order.
NOTE When replacing the right cover, align the tabs on the upper edge of the right cover
Hope this helps
6 Insert a screwdriver to loosen the release tab on each side of the upper face cover.
13 Unplug two (2) 3-pin optical encoder wires.
forward to remove.
