Question about Ricoh Aficio CL2000N Laser Printer
Ricoh Printer Setup & Support Call 1-8O5-225-669O We are 24 Hour Available Call For Help//,
Can you help me find the printer driver for my Ricoh Aficio CL2000N printer? Also, Where do I down load it to? Which sub-directory? Thank you, Tom
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
If you want technical support of Ricoh, you can contact us on RICOH Printer Support 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/HB5mqL
Posted on Aug 09, 2017
Go to the following link. At least this is where I found the latest driver for Mac OSX 10.5+
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/c30e/c30een.htm
Posted on Nov 29, 2008
Anonymous
SOURCE:
How to prink on cardstock on Ricoh Aficio CL2000N
To print on cardstock:
- Load the cardstock paper in the paper tray and make sure the fences are snug but not too tight.
- Press Menu.
- Scroll down to find Paper Input and select it.
- Select Paper Type.
- Select Tray 1.
- Scroll to find "cardstock" on the list and select it.
You'll also have to set your print driver for cardstock or auto select, because if the print driver shows plain paper and the printer shows cardstock paper, you'll get a mismatch error.
Aug 08, 2010 | Ricoh Aficio CL2000N Laser Printer
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Where is the black photo condutor on Richo Aficio CL200N located?
I found the manual for your laser printer courtesy of Ricoh:
http://www.ricoh-usa.com/downloads/manuals/printers/cl2000.pdf
Page 5 of the PDF manual talks about the black photo conductor and where its located at.
May 28, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N always have to press go for every print
You must have a "special paper" size set in the tray other than "plain", or perhaps the wrong size, so the printer needs you to override the setting. Check the settings. You can find out how on pages 24, 25 of the "operating guide". Go to the following web page to download it -just select your model from the drop down list:
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
Mar 13, 2009 | Ricoh Aficio CL2000N Laser Printer
Cl2000n Ricoh can't reset add toner cyan in display
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
Jan 24, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N Error
should have a menu option for clearing errors. or just restarting the printer.. to find out what the error is call ricoh support.. typically if you have a printer like this, you have a service contract with company that handles the repairs and maintainace.
Jan 22, 2008 | Ricoh Aficio CL2000N Laser Printer
Message toner is low
save your self the trouble and just buy the toner cartridge you need. I Think you can go to ricoh.com to down load a manual. hope this helps.
Oct 25, 2007 | Ricoh Aficio CL2000N Laser Printer
Error Code
HAD SAME PROB I WORK FOR RICOH DIRECT SERVICE 670 IS ENGINE CONTROL BOARD OK....
Feb 16, 2007 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
274 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
