YOU MUST GET PICTURES AND PLACE THEM IN THE CREATE A SLIDE SHOW AREA. ONCE YOU HAVE SEVERAL OF THEM HIT CREATE SLIDE SHOW. YOU CAN COPY AND PASTE PICTURES FROM YOUR COMPUTER.
Not all HDMI provides sound, older versions of HDMI are video only. If you're using a laptop you could review the model to see if it has sound support, if it's a desktop computer or a graphics card you can again check to see if there is support for audio. If there isn't and you have a desktop computer, you could upgrade your graphics card to a newer model with HDMI audio support.
If it is just showing a snowy picture then the heads will need to be cleaned either buy carefully cleaning them manually or using a head cleaning tape. If you are getting no image at all from the VCR such as the on screen graphics then check your connections from the TV to the VCR.
NOise coming from?? Screen do not show anything is Possible problem of LCD, LCD BULB, INVERTER, CPU, MEMORY, OR GRAPHIC CARD. Issue. Try external for make sure if you get picture Your GRAPHIC CARD, MEMORY, CPU is fine.
If sound is coming from FAN system, That is need to be clean(or Change), Or HDD makes sound that is Coming to DUE.
JMC
first have you on board graphic card?
second what kind of sound is comming out (did you mean system is started but you can not see it or only is caming some beeps from MB)
if no graphic card onboard, try to identify is startin your system or not if yes you have problem with monitor , if no change your vga and take other one because is blowed or defective.
Try looking at the back of the TV and ensuring that the incoming cable is in the correct input. If you have audio and video cables make sure they are placed in the same input. What type of cable do you have directv or comcast?
