Question about Samsung ES60 Digital Camera
When i try to take a picture it says 'card locked'??
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Apr 01, 2011
Anonymous
SOURCE:
My SD card is locked and i cant get it unlocked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 24, 2011 | Vivitar ViviCam 5024 Digital Camera
My memory card is locked am not given lock number how to remove lock 2gb micro
Look closely at the memory card itself. There should be a tiny picture of a lock indicator on the card and a little tab to click or move to the lock position. There should also be a picture of an unlocked lock to signify which direction you need to move that little tab in order to unlock the memory card. Try sliding it to the unlock position to solve your issue.
Sep 12, 2011 | SanDisk 2GB microSD Memory Card
Every time i try to take a picture "card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Jan 03, 2011 | Samsung Digimax S500 Digital Camera
Camera says that my sd card is locked and it isn't
try to put some glue on a your card lock , in unlock position. But be carefully do not delete your picture by accidentally.
May 31, 2010 | Canon PowerShot A710 IS Digital Camera
When i try to take pictures my camera says card locked.
It's the memory card or SD card you have in the camera. (it sounds like)
Try taking the SD card out and if you look at it closely there is a little switch/ thing you can slide. Slide it to the other side, put it back in your camera and try again. Hope that helps
Jun 02, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
My camera wont take pictures says card locked
There is a lock on the SD card
Check this is good.
Regards
Richard.
Feb 02, 2009 | Vivitar ViviCam 3935 Digital Camera
When you try to take pictures it says card locked
on most memory cards, there's a switch that prevents writing to the card. It's on the left edge. Make sure it's "up" (toward the connectors) and not down.
if that doesn't help, try a different memory card. If it still happens, then we know the problem exists with the camera and not the card.
Dec 31, 2008 | Polaroid i531 Digital Camera
Sd card not working
Check to make sure you didn't accidentally move the locking switch on the SD card to the locked position. There will be a switch on the side of the card. One side of the switch says locked, (or has picture of a locked lock) and the other side says unlocked, or has a picture of an unlocked lock. Try it out.
Dec 31, 2008 | Nikon Coolpix L11 Digital Camera
Memory Card Locked.... how do I un-lock it?
there should be a little swith on the side of the card. switch to the opposite and then try
Dec 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
"the card is locked"
try seeing if there is a button on the side of the card that moves up and down... sometimes it gets switched and locks the card...
Feb 11, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Samsung ES60 Digital Camera Logo
59 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
