Question about Sharp AR-5316 Advanced Digital Imager Copier
I have sharp AR-5316 copier.. My print out is dirty. I had replace already the toner cartridge, developer, cleaning blade with new one. But still the printing is dirty..Any one can help me about this problem. What are the other concerns of dirty printings? Hope anyone can help me about this problem.
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Check fixing unit
Posted on Jan 17, 2018
6ya staff
SOURCE:
Anonymous
  • 69 Answers
SOURCE: AR-M455 Printing Blank Pages
hi im jules_09.try checking the transfer roller or the drum charge roller or charge wire both of this unit are responsible for blank copy.either there id a current leak on those parts or your drum and transfer power pack is deffective.is the opc drum not expose to light morethan 8minutes?just check the transfer unit then the drum charge wire or roller
Posted on Nov 06, 2007
Anonymous
SOURCE: Sharp AR 5316
It worked thanks alot.
All I did was to press the #,interrupt,c,interrupt in sequence. The display then went off.
I then press the numeric keypad 1,4 and start botton in sequence.
It's fine now.
A big thanks
Ometan Goodluck
Nigeria
Posted on Dec 03, 2007
Anonymous
  • 146 Answers
SOURCE: add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Posted on Jan 02, 2008
kamalaldurra
SOURCE: sharp copier ar-5316
sharp fo-2600 fax ld error
Posted on Apr 14, 2008
Anonymous
  • 12 Answers
SOURCE: Sharp AR-5316 will not print
The toner cartridge comes in a box and fits into the developer unit. The developer unit is held in the machine by one 'phillips head' screw (usually blue in colour). The silver bag that came with the machine is not toner but actually called a carrier. The developer unit needs to be removed from the machine and the carrier poured into it. Thereafter you replace it in the machine, secure the screw and re-insert the toner cartridge.
However certain settings have to be made on the machine to set the basic parameters for the optimal useage of the machine and this is only done by authorised trained personnel.
I suggest you contact your closest Sharp dealer and ask them to do the necessary.
Regards
Gavin.
Posted on Oct 17, 2008
My copier sharp5316 has error code of f2 pls help me on this.
That is normall a defective developer unit chip, you may have to replace the chip on the developer unit or the developer unit itself.
Aug 17, 2010 | Sharp AR-5316 Advanced Digital Imager...
Poor image
Clean the beaneath the copy glass, clean the laser unit, polish the toner cylinder, and replace toner cylinder cleaning blade.
Jul 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
How i can install developer in sharp copier AR-5316
The steps to take are
  1. Open the toner door.
  2. Remove the toner cartridge.
  3. Unscrew and pull out the compartment housing the toner cartridge.
  4. View to see three screws on the compartment undo them.
  5. Next you see an enclosure with spiral, rigth there you pour in your developer. Then couple.
I hope it worked.
Thanks
Engr. Kachi.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
check the toner. it still have a tape covering the opening . look for a yelow or red tab at the either side of the cartidge.
good luck
if this answer your problem, please rate it
Oct 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp COPIERS - AR-5316
The cleaning blade is in the drum cartridge.
There is no developrer change in that product.
There are 2 cartridges.
The toner and drum.
Toner contains all you need as far as ink. And also the waste sump is on the toner cartridge.
The Drum is a self containted unit that has the cleaning blade and auger built in.
Jan 10, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Jan 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Add developer in sharp AR-5316
Dec 30, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
74 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
