SOURCE: fuel pump relay location on 1998 mustang gt
Im not 100 percent but I would check the underhood fusebox. The lid should have a diagram stating the jobs of all of the fuses.
SOURCE: My 1998 ford mustang v6 3.8l .. is hard to start
So what you saying is it's hard to start cold right? Something in computer system not allowing excess fuel to injectors when cold. Probably sensor Get auto electrician to sort it out otherwise you end up replacing things that there is nothing wrong with They got the right gear
SOURCE: 1998 ford fiesta 1.3 fuel pump problems
tap on tank while someone is turning engine if it starts its the fuel pump if it doesnt check spark them find fuel psi relief and check for gas
SOURCE: 1998 ford mustang 3.8 v6 starting problems.
it's your upper intake manifold gasket. it has a crack in it and needs to be replaced. your getting to much air and not enough gas. mine did the same thing.
