There should be a sticker under the hood near the front with a serpentine belt diagram. If the sticker is missing then you can also find it in the owner's manual. If no owner's manual you can purchase a Haynes or Chilton's manual which will also have the diagram plus many useful tips and repair instructions you may need down the road.
SOURCE: I NEED A FAN BELT DIAGRAM
James,
Reply with an email address and I'll email it to you. FYI, my AllData only shows the 4.7 liter engine used from the 2002 model year and newer.
Charlie
SOURCE: need fan belt diagram for 95 toyota landcruzer...
My 95 land cruiser A/C is good sometimes for 2-3 hrs cold only and then compressor stop on my way from San Jose to Las Vegas trip. Again back to normal cold on the next day and back again with same routine problem. I check the compressor at 35psi normal and no leak. 1. Is that the compressor relay problem? 2. Where is the location or box of the relay switch compressor ? 3. What is the standard thermostat temp. for my truck? 4. What is the difference using lower temp and std. temp. thermostat? My temp. goes up even w/o A/C and then goes back to normal again. My solutions: 1. I installed new water pump , coolant, belts and radiator caps. Do you have any suggestion or remedy to my problem. Thank you and more power to the Auto Doctor.
