Do you get the same error message every time (or similar)? Can you please post it and we can get you a better clue on what is wrong.Do you get the same error message every time (or similar)? Can you please post it and we can get you a better clue on what is wrong.
Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
You can't post conmments that contain an email address.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
rerun your installation software to install to your new picture folder location. Be careful not to overwrite your original folder. I would rename the original to be safe. Good Luck!
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
Unfortunately, the picture error message means that the image been modified such that the camera can't read it. It is possible that the camera thinks the picture was taken by another camera. Since the picture is still good when you check it with the computer, it hasn't been damaged. Archive the picture and make sure to back it up after it goes on the computer. (If the computer couldn't view it, then you'd need some sort of file recovery software and might not get the entire image back.)
Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ACDSee or any other photo cataloging program.
The following is a listing of the error codes you might see on the status panel of the PhotoMAX Fun! Digital 320 camera:
1.FL - Photo memory is full.
You cannot take more photos. Download and then erase the photos in your camera.
2.FE - Flash memory error.
A camera hardware error occurred. This can happen when the power is shut off before a photo is completely stored in the camera. Do not shut off the power until the green light comes back on steady after you take a photo.
3.bE - Hardware problem.
Turn the power switch on and off and see if the error message disappears. If the error message persists, the camera may need to be replaced.
4.Lo - Battery low.
Replace the camera battery as soon as possible. If you continue to use the camera, picture quality will be poor.
5.LL - Low light condition.
The camera does not have enough light to take a good photo. Improve the subject lighting if possible. Example: When taking indoor photos, add additional room lighting.
