Document feeder is jammed
Hello
to remove the paper jam first turn off the printer and open the cover and remeber dont remove the paper opposite always remove forward. if it is hard to pull the paper check for the roller it might need to roll the roller to remove the paper. after the paper jam is removed turn off the printer unplug from the wall and after five minutes plug it again.
thank you
pls rate
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Details of each item are shown below.
[From 1st Page]:
If a paper jam occurs in the feeder, scanning starts again from the first page of the document.
[From Stopped Original]:
If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
