Welcome to FixYa.
I'm pretty sure I know what you're referring to and in fact I can explain what needs to be done to gain access and repair though it is pretty involved (via removing the tub...it's pretty easy once you see how).
It is most likely the seal under the inner basket (spin basket) and it is a non-serviceable part outside of replacing the complete outer tub assembly as shown here...i.e.
I can guide you step by step on "how to" both access this and repair it, or I can send you a complete service manual for your washer, it's up to you. Whatever you think will best serve you.
You will need to provide an email address I can attach the "pdf" service manual to if you decide you indeed want it. I'll watch for your post and we can go from there. Thank's for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Hi again,
Thanks for the reply. That is indeed the correct part, it is cheaper at "searspartsdirect.com" though, check it out.
I will fire off the service manual within the hour, bair with me.
Regards,
Macmarkus :)
I am having the same issue and was wondering if you could provide me with the service manual pdf. Thank you. -Luis
Thanks for the advice, Macmarkus... I would be interested to know the step-by-step to fix it, if possible. Is this the part that should be replaced? http://www.appliancepartspros.com/Applia...
You can send any instructions/PDF to frausimon at hotmail dot com
Thanks again for your help!
Sounds like this would do the trick... Thanks again for your help!
