SOURCE: Bathtub jacuzzi (motor turns runs but nothing coming from jets)
Each Jet will have an adjustment many times right on the jet nozzle. Carefully try to rotate them counter clockwise to open up the jet. This assumes you can here the motor running.
Phil
SOURCE: Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
SOURCE: two person jacuzzi that hasn;t been used for several years. Iron
You are on the right track. Be sure and chlorinate and run the jets at the same time I would let it set for at least a couple of hours running the jet intermittantly and then drain and repeat.
Sound like you have Iron Bacteria. You may want ot contact a water profeessional who can recommend ways of getting rid of the iron.
Properly Chlorinating your well would be a good first step.
What part of the country are you in>
sanray
SOURCE: smell coming from jacuzzi whirpool tub
the jet covers normally unscrew counter clock wise .As far as the smell goes it could be clumps of old hair after time the old hair usually causes a pretty bad smell.Try snaking the drain.This might help.
SOURCE: jacuzzi tub makes noise but jets wont work
sounds like maybe the impeller is just spinning on the shaft of the motor.
