Try to use Leawo DVD Creator.
Leawo DVD Creator is an easy and fast Windows DVD creator for any video
to DVD creation. It can create DVD from popular formats like AVCHD to
DVD, MKV to DVD, MOD to DVD, MPEG to DVD, MPG to DVD, etc., apply DVD menu from various stylish presets in customized background and music. With eight precise profiles for creating DVD, one can put video to DVD in good quality without any technical hassles.
With this handy DVD creator, you may easily create standard DVD in
NTSC or PAL/SECAM and high definition DVD in 720p/i or 1080p/i, no matter what DVD player to play on. It is available to output DVD ISO image as well.
You can use asoftech video converter to convert the video to DVD format
http://www.asoftech.com/video-converter/
I used the program before, quite easy to use and works well.
DVD Creator - Perfect MKV to DVD Converter for you to convert MKV file to DVD and burn to DVD disc.
What operating system are you using? If you are using Windows there is a great program that is called ConvertXtoDVD. Search it through Google. I'm almost positive that It can convert .mkv files. It has done everything but protected files without a problem for me. That is if your using Windows. If you have Linux or Mac then you may want to look for some forums that can set you in the right direction with those operating systems. I currently use Linux and use a program which is called Devede. I think they have Devede for Windows too. To date Devede has worked wonders for me. So you have a few options. Hope this helps!!
If you want to convert your mkv file to dvd then you need a video converter software. One converter I recommend is the Any Video Converter program. It's free and it converts one video format to another quite easily.
Here's the link: http://www.any-video-converter.com/products/for_video_free/
Hope this helps.
