SOURCE: Amp wont switch off of stand-by
Both units have a problem with the output section. In case 1, the outputs are likely to be shorted. In case 2, the outputs are open. The low level and distortion come from you driving the speakers with the driver section of the amp. Both units will need to see a service provider.
Dan
SOURCE: Sound through one channel only.....NAD 310 Amplifier
If swapping of left and right input sources and left and right speakers does not help...you might have a bad channel in your amp.
SOURCE: my NAD C350 amp only powers one speaker channel
over heating is a sign of overloading or over bias
HI...
Is the tape monitor switch on? If so , turn it off.
Are there 2 C shaped jumper wires ( thick) between a set of jack pre-amp/power amp jacks in the back?
If not , you need to jumper those.
