Philips 42PF9630A 42 in. Plasma Television Logo
Posted on Aug 05, 2008
Blue haze on my plasma screen
A blue "haze" develops on my plasma tv screen but only on the left side going from top to bottom. Blue haze, left side of screen top to bottom
A
Anonymous
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 11, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
830
Points
A
Anonymous
I had the same problem, I had to send it back to Philips to get a $900 part replaced. Thankfully I had the warranty with it.
My zenith D52WLCD has a blue haze going diagonally
This a Normal Intensive Use Defects, this a Screen Burnout. Sorry
Sony rear projection LCD pink haze/blue line
Optic engine. No doubt. Those encroaching lines are just going to get bigger and more annoying with every day.
Check with Sony to see if your set still falls under the natural or extended manufacturer's warrantly. Most optic blocks are warrantied for 2 years (3 years or more on some models).
Post your model # and we can tell you if it is covered by the manufacturer.
Purple-blue haze and line across my Mitsubishi wd62530 screen
hi this fault could be the convergance ic also the resistors and capacitors need to be checked, thanks
shaun
1helpful
2answers
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
2helpful
Sony KDF50 rear projection TV with a Blue tinge (haze) on screen
You have a problem within the light engine. This a hugely expensive. If the set is not too old you could contact Sony and see if they will help you out. Otherwise it is not eceonomical to repair
2answers
Blue haze on screen
blue haze on both sides of samsung plasma screen when goes dark or bright pictures. white lines on football ground appear blue???
The driver boards on that side of the set need to be replaced, about $400 for parts.
Blue Haze comes out the left side of screen top to bottom about 3 or 4 inches.
What needs to happen is three specific voltages need to be adjusted on the power supply, You need to set the Ve voltage to 100v, the Vset voltage to 188V and the Vs voltage to 190v. Monitor the set for 24 hours, if haze doesn't come back the unit is considered repaired. If haze returns, then the problem is with the panel itself and wouldn't be worth it to replace because it will cost more than the tv cost you originally
Plasma TV technical difficulty
if you can still see the picture its most likely the control board that's going bad, you will still need a tech out to fix the issue.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
