I would say the drain pump is blocked..........
you could take the drain hose and leave open end at lowest point on the floor into a container
and let water drain out..........easier if you can get machine to outside door and let water drain outside
i did a zanusi last night...stuck in the pump was 9 small coins 1 hair grip and a womans bra under wire............
follow the waste hose at the back of the machine it ends at the pump......... open the pump then check it out...
good luck..
cheers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
