SOURCE: Ricoh Aficio SP-C210SF
driver mismatch don't use the postscript driver unless you have the option installed as an option
SOURCE: Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
SOURCE: how to print middle page from scanned document
Dear! First of all, You should check your printer timer may be it enable and after the completing the time it shutdown automatically. Secondly, You choose custom option and use it command it from 85 to 100 and 30 copies for each it will work completely.
Thank You
SOURCE: i can't set up scenner options in aficio mp2000
look here in Ricoh white papers you should be able to find what you need. http://www.ricoh-usa.com/support/knowledgebase.asp?tsn=Ricoh-USA
SOURCE: Help, my ricoh printer will
Hi, there is an option for how many copies to print in the printer driver. When you hit Print in the program you want to print from, a box of printer options should appear, including which printer you want to print to. There will be a field, probably about halfway down the screen, asking for the number of copies you want to print. Change this to 60 before proceeding and you will make 60 prints of your document or image. Hope that helps!
