See error codes here :
The compact camera displays error code beginning with or System error Sony...
Press the reset button on the bottom of the camera. Then power the camera off, and power it back on again. "I
have a DSC-P50 and was encountering the same problem. I went in to the
camera set-up mode with the memory stick removed and changed serveral
options (Don't remember which ones, although I do remember trying to
change the "Format" setting) When I re-inserted the memory stick, the
camera worked. " E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor
E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor
E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensor
Hope helps.
There seems to be an issue maybe with the zoom aspect of the device. One person fixed it by turning on the device and catching the zooming drum as it was coming out. Prevent it from extending all the was until it starts to retract again. Then let it go.
