British Airways Hand baggage policy informationYou can take advantage of our generous free hand baggage allowance,
which you take onto the aircraft with you. There are size and weight
limits that apply.
Hand baggage allowance
- You are allowed one piece of hand baggage plus a laptop or handbag.
- A 23kg (51lbs) maximum bag weight applies and you must
be able to lift the bag into the overhead lockers in the aircraft cabin
unaided.
- Please see below for sizes.
- Your main piece of hand baggage is up to the dimensions
56cm x 45cm x 25cm (22in x 18in x 10in), including the handle, pockets
and wheels.
- Your bag must fit into the bag gauge, available at the check-in area.
- Your laptop or handbag is up to the dimensions 45cm x 36cm x 20cm (18in x 14in x 8in), including the handle and pockets.
- Your laptop or handbag must fit under the seat in front of you.
Your maximum number of hand baggage items
Number of hand baggage items
Passenger
Type of baggage allowed
Weight
Adults and children(aged 2 and over)
One bag
and
One laptop-sized bag, handbag or briefcase
23kg (51lbs).
You must be able to lift the bag into the overhead locker unaided.
Infants (under 2 years)
One bag (for items your infant may require during the flight)
You must be able to lift the bag into the overhead locker unaided.Musical instruments
- Small musical instruments may be carried as hand baggage
if they are under 126cm (50in), as part of your free hand baggage
allowance.
Restricted items in hand baggage
Governments and local authorities may impose restrictions on what you
are allowed to take on board with you and what you pack in the baggage
that you check in.
European countries
The EU rules apply if you are travelling from any airport within the
EU, including the UK, and if you are travelling from Albania, Croatia,
Iceland, India, Kenya, Kosovo, Norway, Pakistan, Russia, Serbia,
Turkey, Switzerland and Ukraine, irrespective of your destination.
Specific restrictions on liquids
Restrictions on the quantities of liquids, gels or pastes are:
they must be held in individual containers not exceeding 100ml
the containers must be carried in a separate, clear-plastic, zip-top or re-sealable bag
the bag must not exceed 20cm x 20cm (8ins x 8ins) in dimensions
the bag must not exceed one litre capacity
the bag must be completely closed
the items must fit comfortably in the bag
the bag must be x-ray screened separately from other hand baggage at airport security points.
You can purchase duty-free liquids at the airport or on board if your journey is wholly within the EU.
For other journeys and destinations, you should refer to the specific country restrictions.
We advise you not to purchase liquid items in duty-free shops until you reach an EU airport.
USA and Canada
they must be held in individual containers not exceeding 90ml (3 US ounces)
before boarding, secondary searches may be performed if you are carrying liquids.
Duty-free goods containing liquids may be carried, provided they are
purchased after the security screening point. We advise you to pack any
duty-free liquids in your checked baggage where possible.
If you are departing the US or Canada, your duty-free liquids will be
delivered to the boarding gate or pick-up point in the secure area in a
Sealable Tamper-Evident Bag (STEB).
Australia
If you are travelling from London Heathrow to
Sydney and transferring through Bangkok or Singapore or if you are
making direct domestic connections in Sydney:
- you can purchase duty-free liquids at the arrivals duty-free shop
- you can purchase duty-free liquids on board the aircraft
- if you are transferring through Singapore, you can purchase
duty-free liquids at the airport duty-free shop, which will be delivered
to your gate in an Australian government-approved Sealable
- any other duty-free goods containing liquids cannot be carried into Australia.
If you are making direct connections in Sydney to international
destinations, you will not be allowed to carry duty-free goods
containing liquids through any security checks. However, you will be
able to make purchases at the departure duty-free shops.
