Question about EA Sports FIFA Soccer 2008 for Windows
Hi, I have cd key,copy the digits, installation complete, but when want to run game, it is asking me 2 insert the cd/dvd
    Master:
  • EA Sports Master
  • 415 Answers
Hi, you can try the Game CDKEYS again, maybe that will be helpful for you to enjoy the game. Thanks and have a nice day!
Posted on May 16, 2019
  • 94 Answers
Download a no cd crack for fifa 11.. you can easily find it on the net.. google it
Posted on Nov 14, 2011
6ya staff
SOURCE:
Format aspire4736z
Hi there.
To format you will need:
Operating Systems (OS) CD/DVD
Steps:
1) Enter the BIOS when the laptop boots by pressing the Delete key repeatedly.
2) Once the BIOS is open locate the boot disk priority and set prioity 1 to the CD/DVD drive, set priority 2 to the laptop's hard drive.
3) Save changes to the BIOS and exit. The system should now reboot.
4) Insert your OS CD/DVD.
5) Press Enter when the system asks you if you want to boot from the CD/DVD.
6) The OS setup should now start, the first thing it will ask you to do is format your hard drive.
7) After you drive is formatted you can either continue with the setup and install a fresh copy of the OS or you can exit leaving the main drive clean.
~ Slasher_X
Sep 25, 2011 | Computers & Internet
How 2 install left4dead?
first insert CD or DVD of the game, then there will be an auto run program that will appear on the screen if not appear, go to my computer select the drive where the CD or DVD is inserted then right click and choose auto run.. if not again click the drive again whee the disc is inserted then choose open, look for the icon that contains the left for dead set up then left click, the game will guide you on how to install it properly, then after if the CD contains crack just copy it on LOCAL disk C: program files and find the folder left for dead paste the crack on the folder left for dead. if the game does not run,,copy all the disk data on the C: program files / left for dead folder.. hope this helps you
Jul 25, 2011 | Tally Laser Printer 1 - Installation at...
How to get the pc games to the removable disc(J) sandisk.Can not Move them to Flashdrive disc.
It is not completely clear if you mean large PC games or if you mean small PC games.
By small PC games I mean games similar to the games that come with Windows and that appear in the 'All Programs -> Games' folder. Such as 'Free Cell', 'Hearts' or 'Solitaire'.
By large games I mean games like 'World of Warcraft' or 'Mortal Combat'.
Also, do you want to install the games on your Flashdrive or store them there?
If you want to store a large game on your flash drive. Place the CD/DVD with the game on it in your CD/DVD drive and insert your Flashdrive in a USB port.
Open 'WIndows Explorer' or 'My Computer'. Locate the CD/DVD drive that you inserted the game disk in (most likely your D: drive).
In the 'Edit' menu select 'Select All' and then in the 'Edit' menu select 'Copy'.
Then locate the Flashdrive in 'WIndows Explorer' or 'My Computer'. And in the 'Edit' menu select 'Paste'.
While this will copy the files from your game's CD/DVD disk to your Flashdrive you may or may not be able to install the game from your Flashdrive.
You can use this same procedure to copy small games to your Flashdrive from your Hard Drive.
You will need to know where on your hard drive they are located. And they may or may not run from your Flashdrive.
Also you may be able to install and run games from your Flashdrive, When you run the Setup program from you game disk you will usually be given the option to select a alternative location to install the game.
Select your Flashdrive at that point and it may install correctly to your Flashdrive. If it does you should be careful to always use the same USB port or the game won't run.
Hope that helps.
Jul 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Hi.... i lost my motherboard cd i want to format the laptop what steps i have to take complete my format process
if you run winxp then follow these steps 1)Insert the bootable windows xp setup dvd/cd in the drive 2)The system will boot the dvd by asking you (PRESS ANY KEY TO BOOT THE CD...)press enter 3)Then the setup files starts to load on the screen , a blue screen appears , it may take sometime for setup loading process. wait till it gets over 4)after the files get loaded ,it will give you three options press enter there 5)then press f8.then press esc on the next screen if it shows the previous version of windows 6)then you will be able to see your drive there ,the drive which you want to format just press d on the particular drive and it becomes unpartioned space,again press c on the unpartioned space and create the drive again , 7)do this for every drive 8)and for installing the fresh copy of windows choose a particular drive and press enter and then choose the format using ntfs NOT QUICK the third option remember tats it for xp
If it is for vista or 7 insert the dvd of the particular os and then install which doesnt have some complicated things like xp
Jul 15, 2010 | Compaq Presario Notebook
I have a toshiba nb200 when i turn it on i get an error message saying'' the system is not fully installed. please run setup again''...what do i do?
It means Operating System was not installed completely. Do the followings:
1. Insert the CD or DVD of Operating System and then boot your machine.
2. Simply follow instructions to screen to complete the installation.
3. Note that an Operating System have TWO steps to complete before we decleare that OS is installed. In first step it format the hard drive, copy setup files from CD/DVD to formated hard drive in a temp directory. This step is called "SETUP". Your computer reboot itself after this step. It does not mean operating system is installed.
4. In 2nd step, make sure CD/DVD is still in your machine, just watch while OS starts 'INSTALLATION" . You will be able to view the progress.
OS might ask you input OS product key, computer name and some basic network information which you should have handy.
Once Installation is complete, your PC will reboot and NOW you have a full fledge OS on your PC.
Jamil Ahsan
Nov 18, 2009 | Toshiba Computers & Internet
Ea ssports cricket 07
dear friend .
you need to insert the cd for cricket 2007.
(it may be two cd pack)
insert the cd1 then autoplay starts .
and starts installing if it does not start automatically.
double-click on your cd/dvd drive.
after it starts it asks for key which u can get from
crack folder and right click on rid07 aand run as .
it generates the key which then can be used for the installation.
after that it asks for cd2 insert it and finish installing .
for playing u need to copy all files form crack folder.and paste them in your EAgames/cricket07 and replace existing file.them u can play the game.
thanks for reading the solution.
Mar 27, 2009 | EA Sports Cricket 07 for Windows
On clicking start playing it shows cannot locate cd rom
the game which you have is not genuine...!!!
buy the original or search for a patch..!!
Jan 27, 2009 | EA Sports Cricket 07 for Windows
Lg dvd burner
Hi aubyone
Is this a copy of a game or the original. If you're trying to play off a copy, then the game is 10 to 1 copyprotected. You get this problem when a copy protected game is copied and trying to play it from the copy.
Sep 09, 2008 | LG Computers & Internet
Magix Music Manager
Is it really asking you for ur software installation CD?
Most probably it may be asking you for your Operating System Installation CD. Please insert the Windows 2000 SP4 CD into the drive and try continuing with the installation
Best of luck
Have a nice day
Feb 01, 2008 | Computers & Internet
EA Sports FIFA Soccer 2008 for Windows Logo
223 people viewed this question
Top EA Sports Video Game Consoles & Games Experts
Ekse
MegaByteMe
MegaByteMe
cArLoS
Level 1 Expert
Are you an EA Sports Video Game Console and Game Expert? Answer questions, earn points and help others
